What is My Truck Worth?
tuckerd1
WAR DAMN EAGLE!
Princeton, AL
I am up to 6 cars/trucks, 31' 5'er, 3 horse trailers, 20' flat bed GN and 2 small BP trailers now. I need to thin out the herd. I cannot drive them all and I'm getting insurance poor. I hate paying insurance!
'93 F350 CC DRW 7.3, Hi-Mod E40D, 2WD 4.10, <200,000 miles (I'll have to check for actual miles).
See my signature line for photos of truck and Hypermax turbo and IC install.
This is a one owner southern truck. I bought it new in 93. It has spent its life in Alabama. Interior is in good condition with normal wear but with no rips/tears.
Add-ons:
Hypermax Turbo, IC and 3 1/2' exhaust kits (bought new)
F450 Hydroboost (all remanufactured parts, new pressure lines and PS pump tank)
E40D hard parts kit (all aluminum gears replaced with steel)
ReCal Pro™ E4OD Valve Body Recalibration Kit with updated line modulator valve
Deep Aluminum Transmission pan
See E40D parts here
Low Stall Billet Tq Conv.
Holley Red fuel pump with low oil pressure shut-off
Accessory fuse block added under hood.
3 gauge pillar mount (Boost, Trans temp and EGT)
F350/IDI Specific Tools
IP Rotating Tool
Fan Clutch Wrench Set
Pulse Timing Adapter
Axle Hub Nut Socket
Fuel Line Wrench, 5/8" Hex
Injector Seat Cleaning Tool
2 sets used injectors (DPS and BB)
Injector replacement Orings and clamps
Repairs needed
Drivers door needs spring steel replaced to hold door open
Right rear dually fender has cracks in lower 3" but fender is still whole
Silver Burner
Burnin' Oil&Rubber
Beaverton, OR
I'd figure it was worth around 6000, maybe 7000 to the right person, and that's only because it's a 2WD.
hesutton
The Anti-Anderson
Bowling Green, KY
Don, your rig is very nice and I hate to see you sell it. It was very cool to see it in person and meet you as well at the Chattanooga Rally. To the right guy, 6K.
Heath
