What I found under the CDR.
BBCe40d
Red Bluff
I feel bad that my IDI had to sit for so long. I never got a chance to start working on her. So last night I started with light cleaning and I learned that the CDR was a good place to start. Also, while taking of the Air intake. I found the awesome soup bowl! Do I really v
BBCe40d
Red Bluff
Also. Can a veteran help me identify some of the objects I found under the CDR?
The spring looks important! The other thing is an apricot pit.
the spring goes to the Injection Pump for a throttle return,
its placed on the throttle lever and the advance solenoid,(the plunger looking thing with 1 wire going to it, bolted to the IP
DaveBen
Ukiah, Ca
Clean the screen and place it back on the intake port. You don't need junk and bolts in the intake manifold. Cheap insurance!
BBCe40d
Red Bluff
thank you! I changed the serpentine belt, checked the oil- bad! Also break fluid is toast. ATF low. Power steering pump leaking somewhere. No right turn without extreme muscle use. The steering arm? What grease to I use to lube the all the zerks?
BBCe40d
Red Bluff
Oh and the coolant? It doesn't look too bad. No oil. I wil test strip it this morning as soon as NAPA opens.
FYI.
readers have no clue of what youre working on without atleast a vague description.
you have zero description, but it may be a OBS ford.
we simply don't know.
we don't care about your mug, only your truck
BBCe40d
Red Bluff
I am working on a 1993 F250 XLT 7.3 idi with 340,500 miles. It has sat for a few months. I am reading everything I can about being a newbie here. So much information to go over. I'm just happy that it starts. And it made it to the house. I want to give it the proper care and respect that it deserves.
BBCe40d
Red Bluff
Here is my plan. Any advise is appreciated.
1.Dump the coolant. Flush coolant system, using the DIY from this forum.
2.Drop the oil, I don't know what's in there, but it doesn't look good. New motorcraft filter
3. Drop the transmission pan. New gasket and filter. Flush ATF and replace with synth.
4 Rear diff. Pump out whatever is in there and replace with synth 90-140? That should keep me pretty busy and give all my money to NAPA for a while.
Should I take out a glow plug to see if they are the Motocrafts?
rustygold
conway Arkansas
I would test them with a light first. If you pull them might as well get all new.
Sent from my SAMSUNG-SM-G870A using Tapatalk
olsen726
