A follow up to my earlier post. Changed out the FSV . I went with the spendy one that is supposed to be OEM. I dropped the front tank to check on the shower head and everything was intact surprisingly . I also pulled apart the old FSV to see if somethingmight have got pulled in from the tank but found nothing. Filled the tank and primed the system fired up in short order. Also, before spending a good 2 -3 hours wondering why no fuel is getting to the filter head, CHECK THE FUSE FOR THE FSV. I had replaced the fuse after the initial issue finding it had blown but forgot to check it again after installing the new FSV. Anyway, everything works like it should now. Just a matter of replacing a worn out part . Worked great for almost 30yrs
