What do your gauge setups look like?
saburai
autometer/on the pillar from top to bottom;
oil pressure
water temp
trans temp
banks-dynafact/below the ash tray from left to right;
boost
pyro
oil temp (still no sending unit hooked up though.i put it off cus i know my aux cooler cured high temps.)
exact replica in log truck,minus oil temp.
That looks clean. Autometer cups? What are the bigish knobs? Are they just the hold downs?
satx78247
san antonio, tx
saburai,
I called the vendor of that pillar pod (the guy on ebay.com) and asked that precise question. - He said that it WILL fit all the IDI cabs & without "trimming" or modification. - From what he told me last week, the "pillars" are all the same for years & years.
I think I'm going to buy one while he has them at half price, though I don't have the gauges or the turbo yet for my 1986 super-cab.
yours, satx
FarmerFrank
Blairsville, Pa
saburai,
yours, satx
As a guy that has taken a pillars out of all 3 style trucks, they in fact are not the same from 83-94. But on an 89 you might get away with cutting the ends off a newer style and fastening it to your pillars
no mufflers
rhode island
I do like that little display that shows all the temps and pressures, kind of like a modern diesel.
here is what I did.
saburai
Thanks for the good info Frank. What's the rhree gauge pillar option for my '90?
satx78247
san antonio, tx
saburai,
Check out "awesomecarparts" on ebbay.com. His sale price is currently 16.75 with free shipping. - He told me that he will willingly refund my money if I'm not happy.
The item number is: 391363604797.
Btw, I'm an expert on NOTHING. - Check out "FarmerFranks" comment below.
yours, satx
burt
redding,ca
The obs one will fit your 90 with a little trimming. Looks just as good as it does on obs. At least that's my experience
FORDF250HDXLT
Maine & Oklahoma
yeah it's decent setup,thanks.
there are 3 buttons next to each gauge.they were for the original gauges i had in there (cyberdyne digital gauges - which didn't last.poorly built) for a function to show last high points reached during each trip.
(so you could press the one beside coolant temp and see the hottest the engine ran,was neat in theory if the gauges were worth a lick.)
there is one large dial knob.this is to adjust/fine tune/turn on or off/my electric cooling fan controller.
lastly,there is one rocker switch at the bottom.this used to go to a aux cooling fan i had on a aux trans cooler.since upgraded to larger cooler and never required it (turned out i never needed it for my old smaller one either.)
long story short,i could of just said,they are unrelated to the gauges lol.but that would of been less interesting.:D
03wr250f
Hamilton/Montana
burt is correct that it takes some persuading of the bottom of the pod to make it fit. otherwise you can simply cut the end off and not even deal with it, but in that case you more than likely need to have the factory pillar trim behind it. Mine I traded the factory one for the gauge pod. it looks good in my opinion.
BrianX128
Pittsburgh
In the 1990 F350 with zf5 and the picture is upside down ugh and...
1990 F150 with T18 and...
1989 F250 with m5od
fuzzy1626
Taylorsville,NC
Ok having cut these trucks apart...
All 3 pillars are indeed pretty much the same one to the other THAT I HAVE SEEN manufacturung tollerances aside.
HOWEVER...the PLASTIC A pillar trims...are indeed slightly different amongst the years/body styles....
THUS...some trimming sanding or reconstructive work may be required.
JM7.3CW Eh!
