Is there some reason the f150 column doesn't work? I put one in my truck that had an air bag which my truck doesn't. The cruise worked for a little while then intermittently later completely quite working. I put another f150 column w/ an air bag that I happened to have in and the same thing it worked for awhile and then quit working. Anyone have any ideas on this? Sorry about the hijack you can pm if you want.
My ignition is all jacked up..the lock cylinder is jammed and the key wont turn. I tried taking it apart to try to get the lock cylinder out and I broke the plastic push rod thing inside. How much would you want for one of the F250 columns?
