Walmart Batteries
IDI87
California
They work good and usually they die just before the warranty is up. :) Buy the ones with the longest warranty.
any battery will do fine ONLY IF the rest of the charging system and starting system is in good shape. also, be sure batteries are properly secured too.
Leroy
nashville
many of the brands are actually the same with different stickers ..
i get Deka batteries .. they are a big wholesaler that buys new .. used .. rebuilds .. and sell new 2nds ..
i get group 31 seconds (2nds have some minor flaw .. a scratch on the outside .. 0.1 volt off .. or some other little thing ..
I have NEVER had a problem with one of their 2nds .. there are hundreds on pallets .. and they sell before the stickers got stuck on them ..
so brand ? i don't know but they're serious battery people and no junk that i've seen .. plus i can pull right in at the warehouse and they'll install it
but i do it .. just cause i like to do it and tighten it like i like .. but .. they'll help and have everything there in case u need it ..
best part .. new 2nd's cost about 1/2 price then at the store .. i don't remember exactly but i think the last one was 50$ group 31' semi truck battery
chris142
SoCal
I don't buy flooded batteries any more. They corrode the terminals too much. I always upgrade to agm batteries.
Leroy
nashville
i don't blame ya .. if i had a fat wallet i'd do the same ..
till then .. i just check the water once a year .. and have a decent battery charger to keep em' well maintained ..
i have no problem with corrosion .. but no doubt agm will last longer .. and will not leak if tipped over .. can't explode from hydrogen gas ..
Hydro-idi
Lodi, California
Walmart batteries aren't the best but they do work well for what they are. Like towcat said, the rest of your trucks electrical system must be in good order if you want batteries to last long. And always replace both.
If your truck sits, use a battery tender. I got a couple Econo Power batteries made by Interstate for $38 apiece. They work great & keep a battery tender hooked up 24/7 since mine sits in garage all the time.
chris142
SoCal
I buy my batteries from a local battery place. I pay $101+tax for a deka intimidator which is less than an AutoZone gold.
The Bus
Louisville, KY
My bus takes three 27 DP series dual purpose marine batteries (800 CCA, parallel series from Autozone) or one large commercial truck battery. At a $100/ea or about $300 for the latter, I quickly realized that I needed to better understand how to buy/maintain/prolong battery life.
There are only a couple of battery manufacturers to begin with. So batteries are built to their customer's specifications. I used to work for Johnson Controls, one the few battery manufacturers out there. We had people from the battery division working in our plant.
Beside the all of the good information above, you need to look at how the battery is going to be used. In my case, The Bus is driven less than 300 miles a year. I really only drive it in the fall for tailgating. Recently I have made more of an effort to drive it more year around.
The marine grade battery serves my purpose due to how it's built versus the commercial truck battery.
The second thing is when you buy your battery look for the following:
Date of manufacture - in the case of multiple batteries the newer, the closer, the better off you will be. Batteries deteriorate with age, so the clock is ticking on the shelf.
Check the water level in the batteries BEFORE you buy them. If the cells are low or not close to the same level in each cell (near the plates or even worse - exposed plates) do not buy that battery. It should be roughly a quarter of an inch above the plates. I've gone to several locations just so I could buy batteries that were manufactured within a month of one another.
Do not just buy one battery - replace all your batteries at the same time. A weaker battery will leach voltage off the good one eventually causing premature failure of both batteries. The reason for checking the water level in batteries before you buy them. You want them as close/equal to ability as possible.
Once you get it home, check water again. Add DISTLLED water just below the plastic inner sleeve or just up to it - about an inch to no more than 3/4's of an inch below the the top of the battery.
Do this by pouring distilled water into a clean container and use turkey baster (works perfect for this) to draw out some DISTILLED water. Slowly fill up to about an inch below the top. If you over fill it, just draw it out and discard it back into the container you just drew the DISTILLED water out of - not back into the distilled water. Do not contaminate the source of distilled water. Do this for all the batteries you are putting in service at that time.
Once a battery is put into service, there is a little more water evaporation due to initial use. Afterwards, it's more of a consistent evaporation (slight) over time.
If you don't have any new battery washers, die electric grease, and some other battery top coat, pick it up before you leave. Always clean all contacts with a grease free wire brush, coat contact surfaces with die electric grease, and assemble. Don't over tighten you connections either. The fatigue of being over tightened along with the current stress will cause premature failure at the connections.
The last thing you want to do is to check your batteries afterwards - about a week later, then a month later, and then twice a year at a minimum. Ideally once in the Fall before cold weather and once in the Spring before hot weather.
A good thing to have is an hydrometer when checking water in the fall. This will give you a good idea of the battery's individual cell condition. If they are not close in the results, chances are the battery will not make it through the first real hard cold snap.
Look for corrosion around the connections. If they show signs of corrosion, you have a bad connection somewhere, such as failed ground wire or your pushing too much voltage back into the battery. The heat generated from the stress will cause the coating and die electric grease to melt off over time and corrosion will follow.
Check the fluid level if you have been over too rough of terrain or a little sideways ;Really.
The last thing to check is the voltage. A good battery at rest will be around 12.6 volts if I recall correctly. This forum contains a lot of good info on charging and values.
I went from changing out two sets of batteries within the first two years of driving The Bus to a battery life over 7 years for the trio! I caught the bad battery before it stranded me on the road when testing the cells in the fall.
My current trio is over 4 years old and test as strong as the day I bought them. Pretty good for a battery group that is only warranted for 1 year.
Cruiseomatic
Defining Insanity
Dark side of the Sun.
Used to back in the day, I'd get a walmart everstart battery, and every three years kill it beyond anything ( Pour all acid out, fill with hard tap water then overcharge for 20 minutes.) and take it back and get a replacement whether it needed it or not. I knew it was going to give before long and needed that truck to always start quickly and not need to worry. Can't do that now. One battery, One warranty. You can only exchange them once now which kind of sucks.
NEVER get a vatozone battery though. They are the WORST! Be its the bottom line or the gold line. Every 6 months they were dead. The manager actually insisted he check my alternator before doing a warranty exchange it got that bad. When everything checked out, He had no choice then the idiot said I wasn't the only one with this problem. I told him I'm one less, when this one gives in 6 months I'll get mine from walmart again from now on and never have to worry again. He didn't like that at all. Actually, I don't get crap from vatozone anymore. Orielly or napa now. Their stuff has gotten terrible in quality. Had a PS pump fail 3 weeks after I installed it....I left it and sold the truck instead. But when it worked, It worked like a dream.....
chris142
SoCal
No problem with AutoZone batteries here. And killing a battery so you get a free one is unethical.
Lance
