Crankybait
Got home from work Friday night late and the box with my Moose pump and injectors had arrived! I had a honey do already planned for Saturday, so Sunday is the day.. perfect weather... I've read and reread all the info sent from Conestoga and can't wait to start in the morn. I do have a couple of questions (ok....4) about the copper sealing rings. 1... They go on the bottom of the injector at the tip? 2... Will the old ring stay on the old injector during removal? 3... How do I keep the new ring on the new injector during installation? Now a question about the return line routing. 4...Conestoga sent a new return kit as apart of my order, the 2 examples of return line routing do not match how the lines are run on my engine. The top IP return goes to the cap at cyl #5, the return line to the filer come from the cap on cyl #1. Then in progression to each cap going the rear where they both sides go to a tee at the rear. Which routing works best?? This is a factory turbo 7.3L. I will be following Conestoga's instructions to the "T"...
