W 250 vs. W 350
redwood logger
usa
What is the difference in the axles, tranny, suspension, between the w 250 and the w 350?
82F100SWB
Sioux Lookout, Ontario,CA
On a single rear wheel truck, the rear brake shoes are 3" wide from the factory on the 350, drums are the same between the two though. A pickup dually has a wider rear axle, and the dually hubs on the front. I'm not sure if it's the dually that has the larger wheel cylinders or just the 350's in general(the SRW's aren't that common) but all the bigger stuff bolts on the 250 no problem.
redwood logger
usa
So what are the axles under my 93' w 250? im guessing dana 60 front and 70 rear?
u2slow
bilge rat
PNW
Generally 32-spline rear axles on the W250 and 35 spline on the W350.
SixFourShanks08
