And depending on where you are at altitude wise will set the pressure at which you can pump down a system. At higher altitudes with lower pressure you can boil out the moisture in a system much quicker, and as an HVAC tech for 20+ years I like to leave on the pump when servicing an AC system for a good amount of time.
By the way, I love my U-Tube manometer, but have a nice older analog pressure gauge with remote transducer to see where my vacuum level is at.
Remember in a sealed positive or negative pressure environment, moisture is your enemy.
