yARIC008
Drives really slow
Guess I would put this in a van forum if there were one... but upgraded my headlights finally to be true HID projectors..
Basically, got some new headlights housings, pulled them all apart, cut them up some, and installed some new projectors and shrouds with the LED halos. Once i got it all lined up and secured i glued the headlight back together.
I started out with the 50 watt bulbs and the 50 watt ballasts but I felt they were getting too hot for my headlight housing so i downgraded to the 35 watt ballast which runs alot cooler and puts out about the same light output.
If you want I can post up the site where i got all the goodies, pretty good guys I think.
Now I have the really nice sharp cutoff line when on low beams and when switched to high beams it lets all the light flow out which you can see in this video...
http://www.youtube.com/watch?v=zQ0ox7LrCBQ
Here are some pictures to show the new setup sorta.
This is just the lights obviously. Looks about normal compared to standard.
Here is them lit up, halos and projectors.
Here is just halo lit, which i currently have rigged up basically as a Daytime running light.
Here is low beam on road, kinda crappy picture...
Here is high beam.
Here is high beam.
