once you get the glow plugs go to napa and ask for some heat shrink bullet connectors, get 8 of them. make sure they fit tight on the top of the GP, and the GP wiring is 14 ga.
Exactly what I've been after! Thanks you sir!
With a 6.9l glow plug controller (or a manual push-button), that should be fine...I don't think it would be a good idea with the 7.3l system because of how particular the controller is about wire gauge, resistance, etc. If you have thoughts about upgrading to the 7.3l system, I would either put a 7.3l harness in or replace the blade connectors with bullets (as opposed to the converters).I'm thinking I can make little converters - plug one end into the factory blade and have a bullet style on the other side. If I change the plugs over I can just unplug and go - should be safe correct?
It depends...I've seen/heard of push-button systems done in two ways:It's a factory 6.9 system that I'm going to convert to push button once I've got a warm place to do it Does the controller need to function in order for this to work? My WTS light comes on and cycles a few times after the truck starts, is that ok?
I think I bought a 7.3 GP controller with my order, looks like I wont need that...
The second way is to cut the purple wire at some point and run a wire from the controller side of the purple wire to the button, and the other side to the relay. This will make it so that the controller still controls how long the plugs are cycled on and off as long as the button is depressed...this keeps the controller functionality while allowing you to cut off power between the controller and the relay if the controller sticks ON.
Anyone notice on the GP controller 1811059C92 is $32.16 on the Ford parts and on the IH truck parts the same number 1811059C92 is a $138.42, lets hope someone there made a mistake on the price for Ford truck. I'll know when I get mine wether it's the electronic or just the relay controller.
