that truck is so bad a$$!!!! i wish i could afford to dump one of those in my truck, it would make a good reliable daily driver.
No doubt man! I'd like to do a project like that myself.
Heath
Wonder how he cools it?
PSD Pistons will NOT work in an IDI 7.3. Same displacement, but the parts (piston, rods, crank, heads) do not interchange.PSD pistons would be a great addition to the setup since they lower compression down to 17.5 to 1 which means the engine can build higher boost pressures.
Cat_Rebel;278232 If you got the money you can do anything with these trucks. That's the main thing though $$$[/QUOTE said:aint that the truth
I never said you said that. Just disagreeing with you, I'm not trying to flame you or start anything. Sorry if it seemed that way.I never said you couldn't put a DT466 in a truck.
Another thing you will notice about the DT powered truck is that they are running med duty or Military axle's like Rockwells. That right there alone means it will have low gears takes it out of a practical daily driven truck range.
3176 witch?
