94idift
Do you have the fuel maxed out as well on that? Its cool that there is actually a high volume Db2 out now. As far as the turbos go, a .63AR sounds about perfect IMO. What size of compressor are you going to go with as well?
the turbos i have now are t3/t4 hybrids they have t3 mounts i want to find the same turbo with 60 ar comp and 63 ar turbine hopefully i can get wellover 20psi on water **** and break 300 for only makin 12 psi the truck is fast it would be real quick with 25psi +
i daily drive a 5 speed 215 pump 12v with p pump mods and 4ks and this is quicker than that. But well see once i'm finished i will be going to a couple test and tunes on a 1/4 mile strip.
