Turbo rebuild and later install
nic55kel
Nic55kel
Oakbank, Manitoba, Canada
Looking to rebuild banks non waste gate turbo.
By rebuild I mean replace bushings and seals.
The turbo spins freely and no marking of wheels hitting casing.
Looks like garret T3/4 bearing housing. Can anyone confirm if standard T3/4
bushing and seal kit is correct for this?
Pictures hopefully attached.
Thanks.
Boltgun
NC
I'm doing one right now as a matter of fact. Standard t3/t4 kit is what it takes.
ETA: almost forgot, good luck with the bolt on the hot side housing under the oil inlet flange. I had to sacrifice a box end wrench to the grinder to get it to fit in there.
m2rtin
