LUCKY_LARUE60
As I am laid off I decided to go ahead and install the turbo on my truck
I had this thing laying around for over 2 years, this is a factory turbo, there were a few things missing. This is not a Bank, Hypermax or ATS kit but a factory turboed 94 idi.
Rather than put my truck down for this project I am useing a pair of heads with the exhaust manifolds, valve covers and intake manifold off a 6.9 bolted together. This has made this sooo much easier as I can see what needs to be done.
I have most of it ready to put on and with a little luck I will have it ready to put on by the end of the week. One thing I can't figure out is why I need to move the glow plug controller. As the turbo outlet is over near the up pipe and the controller will be about 4 inches from the turbo outlet I don't see the need. If someone has a picture please send me a pic or post it here.
All I need to do yet before I start the install is to get a oil feed line made, finish the air intake and fad up a short exhaust down pipe. I am going to get the rest of what I need to finish it today.
I still have to work on the valve cover for the CDR. Do I need to put something under where the CDR goes to keep oil from going up thru the CDR? I don't want to use a road draft tube as I don't want the smoke under the truck. As I am useing a cold air intake I am plumbing the CDR into it.
I will be posting pic's later.
Jim
Jim
