turbo pedistal drain to intake gasket no longer avalible
benwill1
94Ecabfaciditrb4x4
N.Carolina
Ordered a kit from ATS that supposed to work. I understand that ATS was bought in 03 and some people have had problems getting parts...I'll keep you guys informed....
benwill1
94Ecabfaciditrb4x4
N.Carolina
The kit I recieved from ATS has the correct gromment !!!!!!!! The gromment in the Fel-Pro gasket set is NOT the correct gromment for the factory waste-gated turbo.
82F100SWB
Sioux Lookout, Ontario,CA
Just an FYI for those of you running Banks non-gated systems, and maybe the newer gated systems, the turbo kit I ran came without a grommet. The oil drain is the same size as a PCV valve. What I ended up using was a PCV grommet for my 460(86, carbed) which uses the same valve cover on both sides, and the grommet is made to fit the oil fill hole. I had to trim the outer edge of the lower part of the grommet about 1/16th, but, it worked perfectly.
