Tube size ?
madpogue
Madison, WI USA
Pressure tubing? TP38?
Have you tried asking in the section that's relevant to the engine that's in your truck?
psd's have a few different pressure tubing.
oil, hydraulic, brake, exhaust.
the v-band clamp for the down pipe is a 2.5"
Sorry, the turbo pressure tubing
you gotta be more specific man!
as we have no clue what you're talking about, and your asking a PSD question in the IDI side of the house, your bound to get castrated lol
if you're looking to find out the size of the up pipes, from the exhaust manifolds to the turbo, they are 2"
if your looking for the sizes of the intake charge tubing on a CUSTOM inner cooler, you are SOL
93blklightning
Abingdon,Va USA
Thanks bro, it was late when i posted that question, and i was tired, and not thinking to well haha.
But i appreciate it
Guess i was thinking more about me fabbing the turbo to the 7.3idi than what the turbo came off of
LET ME KNOW HOW THIS GOES. IVE BEEN THINKING ABOUT DOING THE SAME, BUT WITH THE gtp38
93blklightning
Abingdon,Va USA
Will do,
From what I've seen, the TP38 and GTP38 are almost identical except for the wastegate.
There's a friend of mine who has already done a fab with a GTP38 to a 7.3idi
His name is Rocky Raetz, he's got some vids on YouTube
93blklightning
Abingdon,Va USA
The only thing i seen Rocky did that is not necessary in my build is he cut down the pedestal, I've got plenty of clearance.
93blklightning
Abingdon,Va USA
I bought a 1993 7.3 idi, to replace my tired 1990 7.3 idi with 7??,??? Miles
The 93 only has. 9?,??? Miles on her, got my ARP stud kit a few weeks ago..
It's coming slow,but sure
The gated one spools faster and builds more boost. The exhaust housing is smaller.
If it was the powerstroke pedestal he cut down, it was for good reason. You should eliminate the EBPV section.
93blklightning
Abingdon,Va USA
The pedestal on mine is not as tall as his, so there's no need to trim it down
Why do you say i should eliminate the EBPV ?
And yeah, they spool a little faster due to the smaller exhaust housing, I'm eventually going to install a wicked wheel, ...all I'm looking for is 15-20 psi anyway
93blklightning
Abingdon,Va USA
Another problem Rocky had was, he kept shearing his flex plate bolts, I'm running a ZF5, so that shouldn't be an issue
But his truck runs like a screaming demon..so I'm looking forward to mine
Without it being on a powerstroke, you have no way to control the EBPV.
And they're known to leak.
I actually just ordered a 1.0 housing for mine. Hope to get it on before I leave for basic.
For the wheels, go with the WW2.
Bigal093
