kas83
I've searched, and found one thread about converting to cruise. My truck came with cruise control and an auto, and has since been converted to the ZF5 manual, and also a transfer case was added to the mix.
I seem to have everything for the cruise under the hood: servo with vacuum lines attached, throttle cable from servo attached to pump, all wiring connected to servo. On the inside, I'm not sure exactly what I have. The brake light switch is hooked up and operable, and has a splice for my brake controller. I don't have a clutch switch installed, but have a connector with a jumper, wires are both red with a blue tracer, hanging by the fuse panel. I have the auto steering column yet, steering wheel with all the buttons and what not.
If anyone needs any more info to help point me in the right direction, just let me know. I'll go over this thing with a fine tooth comb if needbe to get you answers. I don't have any manuals or wiring diagrams to go off of.
