GOOSE
Happy IDI'er
I may have to get that Speedway gauge for myself, the more I look at it, the more I like it.
No, you will need to do something similar to the picture posted earlier in this thread, using the tubing kit to put the gauge in your cab instead of having it mounted under the hood. Home Depot or a local hardware store will have brass pipe fittings to help you adapt to what you need.
does that tube kit thread right into the scrader valve?
Go back to my posting #28 in this thread. The first go-around I mounted the pressure gauge where you see the schraeder valve. Then I realized that was wrong. That measures the fuel pressure coming into the filter, but won't tell you whether the filter itself is clogged. I moved it to the other port, which measures the pressure coming out of the filter. If you get a low reading you still have to decide the reason: plugged filter, weak lift pump, or whatever. I seem to recall that earlier filter heads may not have that second port, so that might be a problem.
My second mistake was going cheap on the gauge. I used a Mr Gasket gauge. It leaks and the glass fogged over. It's scheduled for replacement. Is the Speedway gauge kit any better? In another very recent thread a member stated that he used a Mr Gasket gauge and it literally blew itself apart, showering his engine compartment with fuel. Again, mine is scheduled for replacement.
