bagpiperjosh
When i got to work this morning my truck stalled going up a small grade at low rpms. I started it and it stalled again. Then i started it once more and gave it a bunch of fuel and had to let the clutch out real quick so it wouldnt stall. and i got it a little further. then it stalled on a flat surface.
I started it again, and it seemed to idle ok after i backed it in to a parking spot.
A few things to note
This morning my truck did seem to be surging a bit ( like jerking back and forth) on lower rpms.
I have been running an unknown amount of gas mixed with diesel that a customer put in her prius at the gas station. ( a prius only holds like 10 gallons of fuel, so i cant imagine its any more than 5 gallons of gas.) and the rest of the tank is waste oil
so at the most, I might have 5 gallons of gas in a 20 gallon tank.
I have never had any issues with air intrusion since i changed the IP and return lines, so i feel that's unlikely.
I have upgraded my water separator so i dont know how likely water could be getting in there, ( the water separator filter has less than 1000 miles on it.)
any ideas?
i dont think i left any important details out
thanks!
any ideas?
thanks!
