Freight_Train
Traitor to the brotherhood
I got a buddy that has a Ram with a 24V Cumapart.Not sure if it is a 2nd or 3rd genny but I know it is the generation where they "fixed" the problem with the IP frying from a failed lift pump.Anyway,He had a lift pump go bye bye(well acted like.Would crank,run a second stumble and die,then you would crank and crank and crank and nothing.Turn key off and back on would crank run and die.Could hold foot down while cranking and would stumble but keep running then smooth out.Romp on throttle it would fall on it's face then rev.).Replaced lifty with an after market(I think Airdog).Still has the hesitation and will up and die going down the road.This is an auto truck also.Any ideas?Not sure how they plumbed the pump setup in but I know it is on the frame rail under the door.
