Scott, just PM'ed you
I think I slightly over-gauged the wire, if anything. IIRC, the factory setup is a single 10 gauge wire on each bank, with a pigtail wire going to each plug. According to a wire gauging diagram, if the plug is pulling 20 amps (which is actually over the 16 amps that Ford said it pulls, according to DieselDon) and the wire is 10 feet long, I should use 12 gauge wire...and I don't think any of the wires are more than 7 feet long. So, while I'm not completely closed to the possibility of the wires being an issue, I would be very surprised if that were the case.dsblack said:I beleive that it is related to the fuses in the lines, Or even the gauge of wire?
Hoss6.9 said:I wouldn't mind seeing the ford stuff too. To see if I need to rethink some things. I am happy with mine though too! I'm glad to see your lucky enough to have someone offer up there info. too! Gotta love that George Carlin line at the end there Scott!
Hoss....
Oh, okay...well, then, I guess I'll bypass the fuses and see if the controller acts any better. If it does, bye-bye fuses...sle2115 said:They don't protect them from the factory between the controller and the glow plug.
Oops; I guess I didn't read that the first time...thanks again!sle2115 said:Also, you are right as my earlier post said about the wait to start wire on the controller.
you want the same greasy harness the gpc came with?The Warden said:*sigh*
Well, I just re-did the wires...bypassed the fuses and whatnot. If anything, the plugs are cycling faster now than they were before...I think they're only staying on for 3 or 4 seconds now (didn't actually time it, though).
Any ideas? I'm guessing that either I got a bad controller after all, or the system is so sensitive to wire resistance that I'm completely hosed and either need to get a factory harness or abandon the setup altogether and go back to a push button (and, with my track record, I really don't want to go that route)...considering how much $$ I've poured into this already, I'm not a happy camper...
