Trouble finding fuel sender for early 90's E-350.
Fredrickson
Newburgh, NY
Hey all..
The fuel sender on my 1994 E-350 has gone bad..and I am not having any luck finding a replacement.
Anyone have any pointers on where to find a fuel sender for an 1994 E350 Van..?
(even better if it's from an ambulance)
Or work-arounds to get something to work?
Original Part# F3UZ-9275-A
Revisted Part # F3UZ-9275-BB
Any help is most appreciated.
Fredrickson
Newburgh, NY
Thanks!
It looks like they have ones for 22 gallon tanks, I have a 35 gallon tank.
I will be calling them tomorrow, and seeing what I can find out.
I came across Nick Pisca's solution of using an aftermarket unit, with some modification to it..
https://www.nickpisca.com/diesel/fu...rd-van-fuel-tank-sender-replacement-tutorial/
I will be looking into that as well.
Is it possible to run with out a sending unit?
Aside from the fuel gauge.. will it affect anything else?
Cubey
Van dweller
Yes, you can without it working. It's just for the gauge.
I don't know if this helps but:
692-248 Fuel Gas Tank Sending Unit Fit for Ford Bronco E53 E150 E250 E350 F450 F600 F700 Explorer Mercury Mountaineer 1989-1998 Fuel Level Sensor, Fuel Pump Sending Unit, Gas Gauge Tank Sender https://a.co/d/hn5Xu7i
Cubey
Van dweller
I have looked at them, but what is the OHM rating?
Dunno. It specifically says excluding diesel but they can probably be made to work. I doubt that the gauge itself is any different from gassers, except the text on the face saying diesel fuel
BlindAmbition
SoCal
Ford gas senders are something like 16-158 ohms, except for older ones, like pre 1981 or something
Ford diesel senders are something like 8-78 ohms
I replaced the sender boards on mine with gas ones and used Auto meter gas fuel gauges
If I did it again I'd figure out something that uses universal sender ohm ranges which is like 30-233 ohms or something because gauges and senders are way easier to find, though would need to be more customized.
HarleyCummins
