The tranny service its simple bud drop the pan change the filter after, the filter is out reach up in the hole the filter neck came out of and make sure the seal came out with the old filter, replace filter close the pan up. Take of the converter cover crank the conv around till you the plug drain it all give it time then close it up. NOW Heres the most important part fill the unit back up with type F fluid forget mercon and all the friction modifiers in it another word for friction modifiers is liquid clutch killers. Type F and you will be happy remember the enginers build these cars and trucks for comfort the average person dont want to feel the shifts and that is one of the reasons for the modifiers to get a smooth shift and to do that you need slippage good for feel bad for clutches
