transmission Help
Haulinhazmat
Fredericktown, MO.
Help I need some transmission gear ratio info. I have a nv4500 in a 93 D 350/ with 5.9 and a clark T237/DT 360 both 5 spds. I want to put one of them behind a DT 466 in a S 1900 IHC. that I use to pull a 39' 16000lbs 5th wheel. What are the 5th gear ratios and will the nv4500 hold up behind a DT 466.
m2rtin
