kas83
Any truck of this vintage that I've had has always had some sort of wheel hop issue. Not sure about others experience, but all my trucks have had stock 4x4 rear suspensions, and in somewhat slick situations or on uphill starts, they have tended to buck a little and chirped the tires. I am not flooring the throttle by any means, just trying to get moving. Either my 85 C6 or my two ZF's, they all seem to do it. And it is most definately not clutch slippage or shudder, this comes solely from the rear suspension and you can see it in the mirrors as the tires get closer to the fenderwell.
Anyways, I'm looking to build a set of traction bars to help combat this, but don't want it to interfere with the travel when I load the bed up or hook the camper to the truck. I'm thinking that the longer the bar, the less likely it will be to bind when the suspension is cycled. What are your thoughts? A couple of my sled pulling buddies have plenty of 1.5" OD 1/4" wall DOM tubing laying around, which I think would be plenty strong enough for this application, which will not include sled pulling either. Anyone have any experience or thoughts on the situation? Thanks for your help.
