tps sensor
MowMan
Texas
Do you mean Camshaft Position Sensor.....I was unaware that the 5.9 has a Throttle position sensor...that is all machanical AFAIK....
redneckaggie
rebel w/o a cause
angleton/stephenville tx
bro said throttle position sensor that mounts on top off the injector pump it's a 93 automatic and the shifts are horrible in it. It hangs up in first, and then hits second and then third and od are right next to each other. it shifts into od after about two seconds in third at full throttle
Lance
