Julianq7
What are the benefits of a smoke stack for towing? Are there any benefits to it besides looks? Also what else would make my 88 f350 idi better at pulling a load? Thanks
Best thing you can do for yourself is start with the basics: Removing restriction to your IDI "air pump"
This means modifying your intake and exhaust so it flows the air in and out of your engine more efficiently.
Typically guys will just remove the muffler on the factory exhaust and weld a pipe in its place, this makes for killer sound NA and is pretty much guaranteed to give you power gains as the factory muffler is very restrictive and gets packed full of carbon over the years, however there are still good gains to be made by a full exhaust system that elimanates some terrible oem designs like the factory Y pipe.
Next is the intake. The factory intake isnt too bad, some will remove the soup bowl and call it good but in hotter climates I really recommend you make a cold air intake so the engine breaths cold air from outside the engine bay. This will also give you noticeable gains in EGTs.
Did I say EGTs?!
Yes with modifying a diesel the biggest limiting factor are the EGTs- the Exhaust Gas Temperature. This will read what temperature the gasses flowing out of your engine reach and with our engines, 1200* is the LIMIT. Buy yourself a pyrometer and install it properly to save yourself a melted piston.
So, you now have a better flowing engine with denser, cooler air feeding it. Now its time for MORE FUEL!
Here is an excellent writeup on how to do that...
http://www.dieselhub.com/performance/idi-injection-pump.html
Make sure you adjust one flat at a time.
Timing also plays a huge role in the performance in these engines, by our research they perform best at 8*-9* BTDC
Get yourself a timing light and an adapter or go through our timing register to see if there is a member near you who would time the truck for you. icanfixall also has a timing meter renting program.
So basically 1. taking the muffler off and straight pipe it to get better flow 2. get a cold air intake (and what product do you suggest?) and 3. pyrometer and turn up the injection pump.
That should give it the ability to tow bettedr correct?
