w123suv
This is in an E350 IDI N/A ambulance van. Previous owner swapped 4.10 axle for a 3.55. It works well when not towing and it worked ok with a small 2k travel travel but now I've been using it to tow a larger travel trailer i believe around 4k (21ft). It does ok but as soon as I hit any tiny up hill we slow down.
It's annoying but even if I can live with it, am I hurting my transmission by doing so much shifting in and out of overdrive and/ or towing in overdrive in general with that gear ratio. I have done the TC manual override switch and if the hill uphill is small or short I will just unlock the torque converter and that usually does. Is that a bad idea?
Thanks for your thoughts.
