After some digging I found this zip file on FTE with all the updates, codes and trouble shooting its a great file,LOTs of info.
http://www.ford-trucks.com/forums/120175-rebuilding-e4od-33.html
Scroll down to were it says zip file on post #487
If I had low oil pressure I should be flashing code 62/628
Before or after overhaul code 62/628 (TCC slippage).
Code 62/628 will set when the computer calls for LU but does not see
1. Change in rpm (no LU at all- electrical or mechanical problem).
2. Enough of a change in rpm (converter clutch or forward, intermediate, direct or
OD clutches slipping). Usually converter clutch then directs.
Cause and correction
Mechanical
Listed by most common
1. Warped or cracked LU piston. This is the most common and number one
reason for code 62/628. Ford completely redesigned the piston making it
much stronger. LUK manufactures the new piston for Ford and when you
buy a rebuilt torque converter always specify that you want it with the
updated piston. The rebuilt converter costs more money because of the
updated piston but it eliminates the most common cause of code 62/628.
2. Slipping direct clutch (especially common in diesels) Make sure your using
E4OD frictions and not C6. All diesels should use 4 frictions in direct. Use
only steel sealing rings on center support to prevent high clutch circuit
leaks.
3. Pump- A worn pump with excessive side gear clearance will produce low
pump pressure, which can be enough to cause the converter clutch to not
hold or slip setting code 62/628. Make sure the pump you're using is perfect.
If not and you have to replace it Ford has a updated pump assembly with
larger gears for increased volume part # F5TZ-7A103-A.
4. Make sure converter clutch shift and apply valves in the stator are not
sticking or that the springs are not mixed up.
