Torch to Spindle
adamsanders
Virginia
I am in the middle of a ball joint job and it looks like I may be the first person to service this Dana 50 axle since the truck was new in 1991. After I removed the spindle nuts, the spindle itself was seized to the knuckle. I had already done the other side so I new I was in for a fight but this side just would not come. I eventually pulled out the torch and began heating the spindle around the mounting flange. I know this is probably not recommended and I started thinking about the heat treat that may be on these parts from the factory. I had the spindle pretty warm and the spindle studs were cherry red for a short time. Are these studs something I should look at replacing before I reassemble? The spindle was not glowing or anything but it was definitely very hot. Also, I figured I would go ahead and get the outer u joint while I was there. Looks like while removing it I bent down the “lip” where the snap ring sits. Anybody have a method for bending these back other than a hammer and punch? Thanks!
I would think that replacing the studs would be a good idea at this point. You don't want to take chances with these. 8 new studs and some labor is a lot cheaper than it would be if the wheel came off at highway speeds.
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
It’s worse than that....it’s 5 studs about 7/16 that keep the whole wheel/tire/ hub/ spindle on the truck. Please be sure to change those! Remember it is the near press register for that keeps the spindle on, assisted by those 5 tiny studs.
My fault. I automaticly thought of the wheel studs when I read that. I should have read a little closer. YES replace those for sure!
YJMike92
NW Arkansas
Selahdoor
Index Wa
Randy Bush
Great Falls, Mt
nj_m715
government's finest
NE of Atlanta
you could file/dremel the grove for the snap ring
but cherry red is probably a little warmer than "pretty warm"
you might think about a junkyard/ebay replacement
theres a couple on ebay for 60$ or so
Selahdoor
Index Wa
It still keeps things from rusting together, I use it on lug bolts all the time. I am sure it is about as water resist as any grease. I use the gray Permatex stuff, have for years.
True. I still recently bought a new bottle of the grey permatex stuff, even though I have, and use the green grease now.
chillman88
Central NY
I used to use the regular permatex but won't buy it again. It washed out way too fast. I bought a bottle of "marine grade" antiseize. Holds up MUCH better and doesn't dry out as fast either. Might still be permatex, not sure but the marine grade is way better.
Cv axle
