You know after owning a few RX7s mainly the second gen with the TMIC I can tell you what the IC temps are with it TMIC, FMIC, and V mount. The top mount on the track would near 195*, where the FMIC would stay a cool 110* at all times unless the air across the IC would slow down to a slow 30mph, then upon acceleration it would get hotter because of the amount of air going through it vs the air going around/through it. There was a barely noticeable amount of lag with the fmic as opposed to the TMIC, but the TMIC had a noticable increase in power across the band. The best setup, that uses the most efficient way off cooling the intercooler is the V mount setup, but I cannot see this being a viable option on a truck, because the proper ducting needed, plus the space for both the radiator and the IC to lay flat is slim to none because of the size of most of the unit. Since I installed my FMIC I have had one bent fin and it was my own fault I followed a dump truck into a coal mine and one got dent up because of a rock.
