Tool rental...?
whitehorse
Jacksonville Al.
Ok so we have members renting timing meters so how about the freeze plug tool? I have a friend that's giving me a sweet deal on a low mileage 7.3 it's just got a plug leaking and need to replace it....
I caution you about this sweet engine. If one freeze plug is leaking the rest are not far from leaking. Replace them all and purchase ONLY THE FACTORY PLUGS. They come in a bag of 7. Your engine may have been rebuilt and some fool cut corners by installing after market fakes especially if they are brass. Use a wire brush and a good sealer on the new plugs. The tool is essential for proper install. Sadly we have no idea if they are installed correctly even with the correct tool. The factory plugs are stainless steel and are cut to bite into the cast iron block so that MUST be clean.
cpdenton
Truck needs paint.
Conway AR
still coming this way? Bring that engine with you and use my freeze plug tool.
cpdenton
Truck needs paint.
Conway AR
Wife is having surgery on Friday, so I might need to meet up with you Thursday.
Happy to let you use it!
whitehorse
Jacksonville Al.
I wished I could drive my idi up there but I got a few bugs to work out...my brother wants me too also...we will be in the lead sled vic... I hope everything goes well with your wife....
cpdenton
Truck needs paint.
Conway AR
Were you able to get your hands on the 7.3?
Curious how things are going.
chris142
SoCal
Leaking freeze plugs mean an unmaintained cooling system. Do any other engines use this style of freeze plug and tool
whitehorse
Jacksonville Al.
Supposed to get it tomorrow... But may not happen cause I don't think he has pulled it yet..may spend new years pulling it....
Seeing they are stainlesz yes it would surely seem to indicate that....
Not that I am aware of nope never seen plugs like these on other engines...others may have...so possible.
cpdenton
Truck needs paint.
Conway AR
If you need that tool back I can ship it tomorrow...
Nope! Not in a hurry! Just hoping it works well for you.
You have seen the tech article by RLDSL right?
I do expect pictures when you get it done.
