I need to put on a new master cyl. Can anyone tell me how to benchbleed it? Also will i have to bleed the entire brake system after putting the master on?
well bolt the master cly on dont connect the brake lines have a buddy on hand get a basic bleeder kit that works for the master cly put the clear tubes into the resivors pump it till the air is out (air bubbles) connect the brake lines start bleeding the brakes at the right rear then to the left rear then to front right then front left and should be good
Just be sure you get a Master Cyl bleed kit, it comes with adapters that screw int the line holes and has nipples for put your hoses back into the reservoirs. I just did it not long ago, alot easier then other cars Ive done.
Good luck, Jeremy
