94turboidi
Okay well I had the truck too advanced yesterday and I moved it a tooth and it seemed like it was the very same, maybe I put it back in the exact same spot, dunno. Well I got tired of pulling the injector pump blindly and wanted to see what was going on. I tore the front of the motor apart and managed to get a few pics that aren't the best before it got dark. I turned the engine and lined up the indent on the crank gear and there is a 0 at the cam gear so they are lined up. But if you see my paint marks they are off a whole 90 degrees from where the y would be on the injector pump gear. This is what I ran into yesterday when I put the engine at TDC and counted out 19 teeth from each side of the Y on the Inj. pump gear and put a line straight across and tried to put it in there and was showing that it would be 90 degrees of movement from where I had my paint mark. The reason I am still kind of relying on my paint mark is I know I put it there before I removed the injector pump housing. When I put the engine together the first time it was retarded but I was able to turn it as far as I could to the passenger side and it was hard to start but would run almost normal but had gray smoke. Can the injector pump function 90 degrees off or is there something else going on with these marks? Could the cam or crank gears of been removed at one other time and put on wrong? I haven't looked close enough to see if they are removable or not. It was getting dark as I was finishing up and we have a storm coming in so I just got everything picked up before it got too dark. I hope some of the experts can look at this and chime in.
I just noticed that I must have had the camera on high quality and each pic is 3.4 MB hmm......I might try to change the settings and go take another one. I have one on my phone but it doesn't show up as good as the camera.
