larson
Once I start my truck up some times you can hear the throw out bearing rattling/vibrating what ever you want to call it. If I quickly give a little touch on the clutch pedal it stops immediately. Is this rattle caused by the fork vibrating against the bearing? All parts involved with the flywheel and clutch have about 10k miles on them so they are very new. I greased the **** out of the inside of that plastic sleeve on the throw out bearing that slides back and forth. It operates and functions very well just makes that rattle in neutral every once in a while mostly in the morning or after work where the truck has been sitting for hours and cold temperature wise.
