nicksorenson
Thought it was Air in Fuel, turned out to be Timing!This thing Runs like A New Truck!
Well the truck is like a new truck now! I had quite a bit of air in the filter when I first bought the truck. I changed all suspected leak points (o-rings on injector caps, return lines, bypassed fuel selector valve to direct to tank). Still started hard even after 1 minute of resting. I thought, man I can't crack this one. Finally I decided I'd probably just take it in to the Ford dealer but first....
I noticed that it started easier when the cold start timing advance and idle were on (First start of the day) after the initial startup (the following starts) it stuttered and smoked like crazy for about 30 seconds then smoothed out.
So, I advanced the timing about 1/16-1/8" or so and WOW!!! No smoke, starts at the touch of the key and IT FLIES!!!!!!!!!!!! I'd bet my fuel economy is better as well.
One question though... I'm getting no Black smoke whatsoever. That's Good I think??? But now that I have advanced the pump (From where it was before), do I need to get a Pyro? I'm under the impression that a Pyrometer is needed only if I turn the Fuel up. Is that correct?
