Thermostat & waterpump install
ttman4
Last Nite's Dream..
Hello, last nite I pulled my thermostat on my '94 FTIDI & PO had installed it with tons of Red RTV, no gasket & some offbrand broken thermostat. What gasket sealer you usually use on new gasket as well as new waterpump gasket?
BTW I got new Motorcraft thermostat.
hacked89
Bucks County PA
Thermostat - no rtv
Water pump - aviation permatex
I’ve done 5 or 6 like this no issue no leaks.
I’m not inventing something new either, this is by the book.
Also be aware to use the correct bolts for the top two water pump. Putting longer ones in interferes with the gear for the injection pump and will take out the pump. Ask me how I know....
bulletpruf
San Antonio, TX
The middle two on the bottom can also interfere with IP gear...
typ4
Newberg,OR
Aviation will work on both of those gaskets, Its my personal preference on many.
I use a very thin coating of RTV of both. Only because it makes later clean up easier. The gasket doesn't stick that way.
Ttman, before you install your new water pump, I recommend to lay a flat file across the mating surface of the water pump and gently run it across. I've had burrs on reman water pumps that would cause a leak and this removes any burrs that may be on there. It's also a good idea for new water pumps.
Rdnck84_03
Kansas
I usually use wheel bearing grease smeaared on both side of paper gaskets. Haven't ever had an issue with leaks and removal is usually easier.
James
ttman4
Last Nite's Dream..
OK Thanks everyone for the replies. Tomorrow the day to do more of my fixings. This has turned into a nasty time consuming chore.
Loosen the turbo, replace valley pan grommet, valve cover gaskets, waterpump, thermostat, IP replacement, new injectors, ( @typ4 ), glowplug controller new placement, etc, etc, all on my '94 factory IDIT engine in my '90 CC Dually
