mel-
thanks for the new quote
I'm honored.
mel-
The FSV's fail under normal use with #2 on a regular basis. And that is a statement of fact.
I would disagree here. From what I've seen, a FSV will probably fail once in the life of the truck (unless there is a good reason why it failed, like not running #2 or bad wiring). Most of the trucks I've seen have 200-400k miles on them. So I wouldn't call that a regular basis.
As far as me proving wvo, wmo, biodiesel, doing odd things in the fuel system, I cannot prove scientifically in a manner that I could write a paper on. What I can do is try to give you some of the experience I learned in the 3-4 years I've run alternative fuels.
In the last 60k miles I've probably bought less than 100gallons of diesel.....
WMO and especially WVO have a viscosity that varies widely in the 70 or so degree swing we may see in the seasons here.
anyway, I'll let you figure it out. You're IDI memory banks will certainly remember this little trip you just took.... I hope your education doesn't involve your little kids or you getting hurt.
best of luck
Drew
it sounds to me like wmo caused the valve to get blocked on the feed side but not on the return side. basically the cheap plastic spools in those things can get stuck if they get debris or whatever in them. If you have someone flip the switch while you get under the truck you should be able to tell if this is the case, if you hear the click sound of one of the spools moving.
If you hear nothing at all then maybe the vavle is just bad - but it seems strange that it would just go out right on the first big trip with wmo. could be coincidence but more than likely the entire incident was brought about by the wmo. I suggest logging some local miles on wmo to make sure the whole system works well before trying another long trip.
Paul
i don't care if you filter to 1micron, wvo and wmo can do weird things inside a tank and in fuel valves,
Please remember refineries and oil companies spent millions of dollars finding the best additives to add to fuels.
You really need to consider an electric pump. If didn't use one yet You'll see it is a hole lot better than draining the batteries to get air out of the fuel lines.
