jaluhn83
Did you check the ID? Having just had a 92, 87 & 85 petal together it seems like the later ones have a smaller bore but maybe that's cause they didn't use plastic bushings? I can't recall why exactly (which is really bad since this was like 2 days ago ) but I remember noting that they weren't quite as interchangeable as they looked.
Conversion is a very easy thing to do - you need a saw, a drill and a welder. Cut the old pin flush, then drill and weld a new one in. I used a grade 8 bolt - I'd think grade 8 or 5 should be fine. I picked 8 since that's what I had and I figured the harder surface would help with wear. As long as you use a bolt or something with a head, the weld really isn't that critical - the load is 90% shear on the pin and the weld just holds in place. There's no real load on the weld unless you really goofed and made the hole 1/4" bigger than the bolt or something.
The stock pin is 9/16". I used a 1/2" bolt so that I could use a bronze bearing insert instead of the plastic sleeve. I'm waiting to get the master hooked back up to see how well it actually works out. I also rebuilt the clutch master pin with a 3/8" grade 8 bolt and a bronze bushing so hopefully no more clutch pushrod wear.
