junk
On the way to work the 89 started ticking and blowing white smoke out the exhaust. At idle it's running rough also. So based on the white smoke and running rough I'm thinking fuel system. Bad injector probably? I'm not thinking valve train because it isn't running consistently rough. It kind of comes and goes.
So on the way home I noticed this.
-Gages were in typical ranges
-Oil level is good and typical color
-Truck ran Ok, but you could tell not right
-white haze from exhaust that would come and go
-Starts great still.
I cracked the injector lines right after work and didn't necessarily see a difference between them, but I'm going to do it gain once I pull the intake stuff off and get into work clothes.
Am I on the right track for trying to diagnose a fuel system issue? What rules in or out valve train also?
