dizdak
last couple times i have started the truck i have noticed that the tach seems to not respond or only show around 100rpms, then usually after running for a few and them a little slap of the throttle it picks up and sits where it should... where should i start with seeing if there is just a bad connection or what not? or should i even worry since so far it picks up and seems to be working correctly after the engine sees some rpms to make the needle move a time or 2?
