datkinsonsr
I hope you all had a wonderful Thanksgiving! My tach quit working. I Knew the sensor was leaking oil around the wires and tach was barely indicating until engine got up to temps. Then tach quit altogether. so I replaced tach sensor with new Ford P/N. Still doesn't work. Checked the fuses, all ok. Pulled Tach and inserted a gasser tack I have, still no work. Made sure all the plug connections are good. Also, I now only have 2nd and 3rd gear working on my E4OD since this happened. Up until a couple of days ago, everything was working very well. No issues. I don't know if this is related, but a couple of weeks ago, I had the tranny pulled to fix some leaks and a new flex plate installed. When I picked up the truck, it didn't want to move in drive. Placed into low gear and would move like it was in second gear. The shop replaced the gear position sensor on the side of the tranny and it seemed to work ok. At that time, I did not notice if the tach was working. Any help will be greatly appreciated.
MERRY CHRISTMAS TO ALL!
