tachometer help OBS
this is one of the two last item of concern.
cannot get the tach to work.
I have a new sensor on order.
but seeing is that this was a E4OD truck before,
im curious if the tach wires that the E4OD is dependent on
actually go through the trans.
the ECU is deleted.
thinking I need to jump some pins.
anyone have a thast diagram for the E4OD connector?
and the ECU wiring diagram?
Black dawg
sw mt
ON the e40d to manual swaps I have done, the tach would not work without the ecm. Usually just left it in there...tach works smoother with it. I am sure wires could be jumped to not use the ecm
FORDF250HDXLT
Maine & Oklahoma
full
laserjock
Almost there...
I believe this is the one you need.
If you look the tach has 4 wired to it. Power, ground, signal and signal ground. The wire you care about I believe is the white-pink. It is the tach signal wire. If you go to the upper right hand corner you see the tach sensor. Notice it also says w/e4od and w/o? The one without connects the tach sensor to that wire. The one with says it gets the tach signal from pcm pin 36. I believe you said that you used the auto harness so you are missing the tach signal without the pcm. Need to connect the tach sensor tan/yel to that what/pink I believe.
I can.
I cannot read fordhdxltlariat4x4drw's pic, minus the cut out view
FORDF250HDXLT
Maine & Oklahoma
Yeah mine uploaded really compressed here to my media album for some reason.Yours is good Mike.
Let me see what happens when I post mine directly to a post too.......
Oh,holy crap.Way better.Especially when you click on it ^ I might try re-adding it to my album.Maybe I uploaded a compressed copy there by mistake.
You can save this copy here,to your pc and zoom way in too.
mucho betorro, grassyass!
When my tach "SEEMED TO FAIL" last year it ended up being a failed fuse able link behind the passenger side battery splice made by a previous owner before 1996. Also I found a techa relay near the window washer resivour. For a quick fix I jumperd in to this relay from the battery positive so I could drive my rig. This forum gave me plenty of wire schematics and help too. Might search my posts about failed tach. Even U tube helped me too. That splice was three of those blue crimp line deals in about a 4 inch run attempting to save the fuesable link.. What a foolish idea that was. Sometimes closing the door would make contact enough to work. It drove me crazy looking for an intermittent open circuit too.
