Tach n time help
jeepj667
SL,UT
Trying to time my truck. The display reads rpm correctly but the timing always says -20.0.
What am I doing wrong?
Sent from my Nexus 6 using Tapatalk
Clb
Another old truck
nannyfornia
Ya need to hit the second rocker sw.
Mine is burried, there is a tech thread by Icanfixall somewhere
jeepj667
SL,UT
First pic is what it's stuck on. Second pic is I flipped the switch to timing light. Third is flipped switch back to magnetic and it wants me to set the offset again. If I push the set button it takes me back to the first pic.
Timings got to be close. It fires right up.
Clb
Another old truck
nannyfornia
Hit and hold for 2 seconds, the bottom switch.
It will set the 20* offset(this is from memory)
It should then show tack rpms and timing
Clb
Another old truck
nannyfornia
Btw
these will run near -10*
Search don't be retarded...
brian and I had a hella time!
What does the book say?
Clean metal contact?
Try #1and #4 Injection line.
Clean, close to inj. As can be
jeepj667
SL,UT
I figured it out. I didn't have the magnetic pickup inserted all the way.
I was assuming since I was getting an rpm reading the magnet was working.
Currently set at 8.8. Gonna leave it there for now.
