PwrSmoke
CaptTom: As I said above, you are mistaking the winter part of the grade, 5W, for anything meaningful on the hot side of the equation. The only danger with a wide spread between the two grades is that the oil may shear down a little, but between the syn base stocks (all 5W40s are syn, whether GpIII or higher) and the higher quality VII (Viscosity Index Impreovers) and PPDs (Pour Point Depressants), that's not a likely scenario. All the PSDs (HEUI) are known "shear-monsters" but they seldom can beat down a syn to any dangerous level. The tests I see show that sometimes they can beat it down into the upper 30 grade level towards the end of a run, but that's not dangerous in my book. From what I've seen and experienced myself, the IDIs aren't shear prone, beyond a normal level at least, so I don't think we have to worry about that without our old tech powerplants.
To answer your question, "best" is relative but in a warm climate I still don't see any worries with a 5W or 10W oil. If you do, at least the warm temps and syn base stocks will minimize the efficiency losses with a 15W, so feel free to run with it. Rotella also has a 10W40 T-5 semi-syn that I see all the time at Tractor Supply. It's about $20/gal there where the full-syn 5W40 is $24 (IIRC). Might be a good compromise to calm your nerves ( : < ).
