bobracing
Well the engine fits fine, the question is wiring and that extra A/C sensor.
Are all the plugs the same? And can just be extended and plugged in?
Except for the two glow plug wires that are upgraded to a more direct power wire and can/need to be cut off.
What is the extra sensor on the A/C hose for on a 93? Up to 92 that sensor isn't there, does it need to be hooked up when put into a 89?
The truck is an 89 F-350,CC, 4x4
new engine is a used stock 7.3 turbo from a 93, think a 2wd F-250.
Thanks
James
Thanks
James
