superduty lift springs on older ford f250
Kodeman
Esparto,Ca,USA
hello, i have a 1999 f350 SRW pickup with a 6" lift on it, well i am taking the lift off and going back to stock springs for better towing, my question is , i have a 1992 f250 flatbed im looking on lifting, has anyone put superduty springs on an older ford? if so do they match up well? any help would be great. thanks
'99 and up are completely different animals compared to the '97 and older.
I'm not saying you CAN'T do it, but you're going to spend much more than you really should to make it happen.
averagef250
Portland, OR
The 98+ superduty front springs are close enough to interchange with 67-79 stuff, but they will not work with 80-97 leaf sprung stuff unless you use rear shackles and move the shackle mount to accomodate the different spring length. No idea where the axle centerline will be either, this might make it a no-go period. You'd have to measure to be sure.
If you adapt the newer springs, realize you need to maintain the 3-4 degree spring pad angle otherwise you'll be running angle shims in front (bad idea) or turning the knuckles on your front axle.
biggin92
Yeeeee Haaawwww
umatilla fl
i've heard the sd springs are longer in the fron like 3 inches so u would need to move your shackle mounts forward like 3-4 inches
