aiyana7.3
IDI Enthusiast
While driving my truck yesterday I noticed that whenever I was accelerating, the Brake In Park Light, Engine Temp, and Fuel Filter light would come on and when my RPM's got back down to cruising speed the lights would go off. (My rear abs light is already illuminated due to problems I'm having with the brake light.) Later that day, the Water in Fuel light also came on with all the other lights. A couple minutes later they would all come on and stay on whether or not I was accelerating. All of my gauges read normal- Oil Temp, Fuel Pressure, Engine Temp, Exhuast Temp, Transmission Temp, Vacuum, and Fuel Pressure. The Volt meter would go down so it is point right at the N of NORMAL and sometimes just slightly below that if under a load. Today, when I turned my truck on before starting it, all of the lights instantly came on and will not go off.
Other problems that could be related;
Brakes are spongey. I believe it has to do with the Rear Abs since I have replaced everything else.
I have a fuel leak that will leave a puddle of Diesel under the truck if the engine is running. It must be on the return side of the system for it starts and runs perfectly.
Thank you all so much for all the help you have given me so far. There is no way the truck would even start without all your help!
