Greg Pettit
Had a hard line break at the injector pump end. I believe this was a metal fatigue issue which I may have had a hand in causing, because I left off the metal clamp that straps those 4 lines together over the intake manifold.
The result was loss of power and a major fuel leak.
Since we were 150 miles from home, I simply reversed the injecor line and attached the injector end to thepump. I then removed the fuel filter housing's return hose and clamped it on the end of the injector line. Finally, I plugged the fuel filter's return fitting.
The remainder of the drive was on 7 cylinders pulling 7000 lbs. No problem, but not optimal.
Where does a guy get a replacement hard line? IH? Ford? Has anyone heard of these things breaking before?
Thanks for any help,
Greg
Greg
